Hi all
I've read through this thread http://community.whathifi.com/forums/1/165979/ShowThread.aspx about possible upgrades to a Rotel RA-04. I wanted to understand a bit more about power amp compatibility.
My RA-04 is an obvious pairing for the RB-06, the (recently discontinued?) series 06 matching power amp. The other thread talks about the RB-03, which looks like the previous generation. Ebay has a pair at the minute, but I was wondering what the relative benefits of the RB-03 vs RB06 or some of the older 9xx power amps on ebay? Both of the 0x amps are 70W, looking at their specifications there doesn't seem to be a lot of difference other than age.
I think my options are limited to the 03 and the 06, but perhaps there are others? Are these worth the money, or will I see little benefit? I could run them as pre / power amp or bi-amp which would add another 60 odd in speaker cables.
Music is a mixture from Fleet Foxes to Telepathe, White Stripes, MGMT and bass heavy stuff from Warp plus some classical and jazz. Source is mainly lossless rips via iTunes from my macbook.
I'm happy with my BR2s and the Rotel for the moment. I'm really wondering if chasing this cheap power amp upgrade is worth it or if I should get a DAC instead. I am buying a iBasso D10 for portable use and we are moving towards the end of the year, so might be getting a whole other system at that point, as we'll have a much bigger room too.
hence the question, would 100-150 odd quid spent on a matching power amp for the RA-04 be money well spent?
thanks Gavin
thanks Gavin
