[/quote]
Can you post a picture? It doesn't sound a lounge friendly solution, and 2m thick traps are definitely out. I used
this to calculate the main modes, and surprise there are a bunch of them at 43Hz, 47Hz, 49Hz and 50Hz. I've tried experimenting already with speaker position fore and aft, there's little scope to move out wider as there is a sofa running up each sidewall, and I want to keep the speakers from firing directly into them
[/quote]
Ok, so I would say, just take a step back from the charts for a min. They deal in absolutes. As in to totally eradicate something, which is essentially perfection.
Which is something that we're always chasing in hifi! But! We don't, we get as close to it as we can.
So no, your not gonna put 2m absorbers in, thats ridiculous and unless your a top end studio, your not going to do! But, is it worth taking measures to atleast get closer? I'd say so yes.
You can put in quite shallow bass traps in the corners, and that will still make a nice difference. The same as 2m thick ones? No, but ones that you can make work for your room that don't intrude too much, yes.
The cloud option I think is a really good way to go...
http://www.allnoisecontrol.com/img/customersupplied/cs_clouds_froggtowninn_1.jpg
https://www.gearslutz.com/board/attachments/bass-traps-acoustic-panels-foam-etc/70921d1215237903-diy-ceiling-cloud-srsdrumcloud.jpg
