Roksan Kandy K2 amp & Dynaudio focus 110. good match?
Yep, it certainly will. The Kandy amps have enough guts to drive virtually anything. My K1 Liii is currently driving a pair of AE2's very compentently. I note the WHF review of the 110's says they can be a touch bass heavy, whether that would cause a problem with the Roksan I dont know - it may need some careful speaker positioning.
As always try it out if you can.
audioaffair
100
It should drive these comfortably. In terms of the sound, I haven't heard this combo but it should work quite nicely - have you managed to listen to it or borrow one yet to try? Always a good idea before buying speakers!
jalaba
7
it's up for audition after the holiday. will definitely try my roksan on it before coming to a decision. haven't tried any dynes before. I'm also wondering if they would be good for rock/metal music. it's a 10 hour drive to have an audition so i would like to hear from those who had been using the focus 110, feedback from those who own it would be highly appreciated. .
Craig M.
127
i had focus 110s with a kandy L.lll, it couldn't control the bass. the k2 might be better, but i would not buy without trying first, the focus 110s require a shedload of current to control them. great speakers though, when correctly matched.
jalaba
7
will definitely audition it with my k2 before buying. how better is the focus 110 compared to the b&w685 or the monitor audio br5? might let go one of these speakers if i get the focus 110. if i happen to like it. too much bass maybe avoided by proper speaker placement.
Craig M.
127
i think the bass is strong but not overdone, if the amp has proper control of them. they also need about 50cm free space behind them. i think they are much better speakers then either of the ones you mention.
