Bips:Hi i have a sky hd and have connected my sky box via rf out to another tv.
The problem i have the other tv picture quality is fuzzy and grainy i have checked the connections and there ok.
the cable connected the sky box to the 2nd tv is brand new. I rang a local shop where they fit sattelite dishes and they advised that the frequency needs to be the same on both tv's im not sure what they mean.
Can anyone shed some light on thisSounds like uhf interference from your local TV transmitter.
You will need to shift the frequency of the Sky boxes rf output (default is ch68) so it doesn't clash with your local channels.
To change the output-On your remote, press "services" then 0-0-1 in quick succession then select "rf outlets". Once in the menu you can adjust the output between ch 21-68.
But,unless you happen to know your local frequencies it will be a bit of trial and error as to what channel to use, and each time you change it,you will need to re-tune your TV to that frequency.
Also the cable i used was black sattelite cable is this correct or im i supposed to use the brown areial cable. Satellite grade cable is of better quality/has lower signal losses than "aerial" cable,so you're fine!
Also which RF am i supposed to use RF1 or RF2
ThankyouThe rf2out is meant for connection to a remote tv, as this has 9v supply to power magic eyes(which needs to be switched to on in the rf outlets menu,if using an eye). If you're not using an magic eye then it doesn't really matter tbh.
