Question Replacing floorstanders
Jan Gaens
16
Current system: Rega Brio amp, Rega Apollo cd, bluesound node 2i.
Current (failing) speakers: KEF Q7.
Your advise on new floorstanders (price/quality matters, not too intrusive in living room).
Mainly listening to classical music but also pop, rock, jazz,...
Are the neat iota alpha an option?
Listening to my favourite boheme recording with schippers, freni, gedda there is a harshness in forte high voices (oh sventata, che gelida manina): can this be overcome with new speakers in the current system?
Size of room, budget might be helpful.
Listening to those recordings on CD?
The iota alpha are not a particularly easy speaker to drive and not too sure how they perform on a carpeted floor with that downward firing bass.
Listening space 5x5m oak wooden floor ceiling 3 m, this space is open to diner space 6x4 m.
Listening to CD for classical music and jazz, for radio and other genres (spotify, internet radio) I use the bluesound node attached to the Rega Brio.
Budget 1000 to 3000 euro.
If i were looking at neats iota series it would be iota Xplorer, think they pretty much fall into your budget (could be wrong) and would be a better fit for your space.
But i would look a Revel 106m don't be put off by there standmount stature they give a full range experience and are able to be played loud with ease, though can compress just a little at the extreme. They're very much a match for any compact floor stander and have one of the best mid/bass drivers money can buy, There best attribute is there very listenable at lower levels which not every speaker can do. At this price and size level, nothing matches them nothing is as dynamic these should be on your shortlist floorstander or not
The slightly more left field option (for some) would be the Klipsch Heritage line of speakers great for anything acoustic jazz, classical, rock (sound like you) though they play everything with aplomb. They deliver crystal clear vocals, lovely mids with dynamics that are unbeatable for the price (not even the revel can match these), though can sound a tad shy on bass, you can't have it all. BUT! Will fill your room with ease with there 99DB+ sensitivity giving your amp an easier life and they go loud! no joke! With little to no distortion and with very few watts, 5 will do it 20-30 will rock your world.
The outgoing heresy 3 model can be picked up very cheaply at the moment. So if you need a bit more weight a little sub could be added with your leftover budget. But the sweet spot is the forte 3. But the best thing is they go against all traditional speaker setup wisdom and can be plastered right in the corners and up against the front wall, in fact, you're encouraged to do so in manuals as a starting point. And they're all hand made and book matched to boot.
Those are what i have tested and compared and have owned and had in my house, in the case of Klipsch still own and will nver get rid of.
Then you have your usual boring suspects 😉 PMC ATC KEF and so on which i also auditioned and in comparison in my opinion the revels beat nearly all but that's me and people are after different flavours.
Rega Brios £599 budget amp if you have up to 3,000 euro budget look at improving source/amp 1st to reduce harshness
34F very liquid & smooth sounding with no harshness
Reactions: filipo and Al ears
Thank you for your excellent input. Klipsch wasn't in my minds allthough I have a pair of
Thank you for the excellent input. Klipsch wasn't in my mindh I use a pair of rp600m in my study room. Do you think these heritage speakers van adress the problem of harshness. The Rega Brio is a budget amplifier. Any idea how a more conventional klipsch RP 8000f would perform?
When you say "harshness in the forte high voices" what source are you listening to or is it the same with all sources?
The harshness isn‘t that disturbing, guess it is also the recording and the high pitched soprano and tenor passages.No clear difference between CD and FLAC (CD better sounding than FLAC over bluesound over Rega Brio 😉). Do you think new speakers can better this?
Very few speakers will do well in that setting. Try some Audio Note or full range driver designs. Alternatively look at in wall if convenience is important.
Insider9 has a point but, personally, your current speakers are not ideally placed. They need to be out further and closer together away from those side walls.
To my ears the KEF Q series were always a tad bright, I would suggest replacing them with something a bit more neutral. Perhaps second-hand Sonus Faber Venere 2.5's
They are pretty far away from thé rearwakl
They are pretty far from the rear wall (0.5m) but close tot the side walls. For concentrated listening I can bring them before the couch.
Good point but he isn't going to get them and a decent set of stands for his budget.
For some reason I prefer floorstanders. Speakers have to be a step up from the old kefq7’s but they should not overshoot the Rega equipement wich i intend to keep a while.
I read good reviews on the q acoustics 3500, dali oberon 5, Wharfedale evo 4.4 etc. Can i do better since i am willing to stretch the budget to 2000 and eventually 2500-3000 euro?
It's very awkward at this time as normally I would suggest going to a dealer and auctioning.
Buying on other people's recommendations isn't a good idea but realise you might have to do just that in the current climate. Buy carefully and if they don't work for you then you shouldn't lose too much if you sell them on at a later date.
Check the dimensions of these speakers and see if they will fit comfortably in the space you have . Each of those speakers you mention have good reviews but it doesn't mean they will work well within your current space, that said I think they will all give a different, and probably better, presentation to those you currently own.
Are you only considering new speakers as opposed to second hand?
Please note also, being in the UK, I have no idea as to what you can get for speakers within your upper budget.
Almost all speakers you can buy in the UK are available in Belgium. Prices here are generally the same or a little bit lower here.
Second hand is harder tot het here comparing to sites in the UK. For instance the sonusfaber venere 2.5 afore mentioned.
Dali Oberon 5 is a good bet, and with the upped budget, Focal Aria 926 or 936 should make great partners. Or SH Sonus Faber Toy Tower or Spendor A5R. On the other hand, with the big budget, another way to look at it would be improving source and amplification - Maybe a Naim Uniti Star - and upgrade the speakers at a later date.
