Help.
My Marantz CD63SE has decided that it no longer wants to play any of my CD's I am not sure if this an objection to my musical choice or purely a mechanical failure.
Anyway, it seems I have 3 options:
1. Get it fixed. I have not looked into this option and have no idea whether it's worth it and it seems like a good excuse to get a new one.
2. Replace it with a 2nd hand CD player.
3. Buy a new CD player that fits well in my set up.
So the important bits; I currently have the Marantz CD63SE, A Rotel RA-920Bx2 Integrated Amp no idea who old this is but seems to do the job well) and a pair of Mission M71's. The CD player and Amp were bought 2nd hand (from a reputable store in Sheffield) along with the M71's. I have been happy with this set up for about 6 years now and apart from the odd look I haven't considered updating anything until now.
I would therefore like some advice on the options above and what options will fit in nicely my amp and speakers.
Realistically I don't want to spend more than £200 but if push really came to shove I might be able to stretch a little further.
Any advice is more than welcome.
Thank you.
Keir
Thank you.
Keir
