How has the speaker died on you? Can you be more specific.Hi there. I have a Monitor Audio Radius 370 which has died on me. Please could anyone suggest what I can replace it with. I’m clueless on what it actually does and therefore what I’d need to get instead. Ex-hubby set up the system 🙄😊
Lots and lots of times I have wondered if my sub had died on me only to find it was a loose cable.The 370 is a subwoofer which focuses on lower frequencies to give a good bass. Essential for movies.
I have a Panasonic TV with a Denon AVR-1610 receiver, a Radius One HD speaker and two Radius 45HD rear speakers. Budget wise around £300 I suppose, but if can get something cheaper that will do a good job then all the better.What's your budget, and what's the rest of the system like?
Good to see you too!
