I've currently got a Monitor Audio Radius set up running -
270 floorstanders, 225 centre, 90 rears and a BK XLS200 sub. This suited the layout of my old room where the TV was on a stand in the corner with the floorstanders to either side.
I'm moving shortly and will be creating a new room where the TV and speakers will be firing across the room with a bookcase built around them. The room isn't huge so I'm planning to use ceiling mounted surround speakers - Monitor Audio C265FX
I know these are supposedly 'matched' to the Silver range rather than the Radius, and I'm thinking it coudl be a good opportunity to move to a more conventionally sized set of main/centre. The MA silver 1 or 2 look the right size. However, I think these are rear ported so won't work well backed against a wall.
Any suggestions? Will my current Radius speakers likely perform better than the Silver's in this scenario (and should I worry about the 'mis-match' between the ceiling FX and the mains - I've not set them up to test yet)
