- Aug 10, 2019
- 2,556
- 5
- 0
Hi. I've just purchased an old Technics SU-V505 amp and want to remove the banana posts so I can attach unterminated wire. The unit originally came with twist and lock sockets which the previous owner then replaced. How do I go about removing them and would I need to find and fit another set of twist and lock sockets in order to attach unterminated speaker cable? I know you can attach banana plus to the end of cable yourself but I really don't want to go through the bother if necessary.
