Recommanded 5.1 Surround Speaker Set
toltol
Hello,
I looking to buy a 5.1 satellite speaker set for my pioneer vsk 323 recevier.
They will be used for home cinema system.
I'd like to get your option on which of the following sets better:
KEF KHT 2005.2
JAMO A102HCS6
Thank you! :)
John Duncan
Hi toltol, and welcome to the forum.
What's your budget? Those systems are quite long in the tooth now so presumably you're getting a good deal on them? There might be some recent alternatives that you should also consider depending on how much you want to spend.
toltol
Hi john ,
These models are used sets i found that fit my budget
my budget isnt really relevent as the prices of speakers in my country are different/expensive
Im looking for input on these two models
thanks
