I am currently looking at speaker stands for my rear speakers and have no idea which way to turn! The speakers are Monitor Audio RS1s. I need to mount them 900-1000mm high. My budget is £120ish max. However due to being in a wheelchair id like something pretty solid, that will not fall with a slight tap (don't drink and drive!)
So far I have got two possibilities-
Apollo A4 (900mm) which seem good, if not completely heavy weight. If mount the RS1s on these then there will be a 60mm overhang depth-wise.
Atacama SL1000 (1000mm) which seems perfect, rock solid (comparitively) and huge base plate 300mm x 300mm. If i mount the RS1s on this then the top plate will be about 40mm wider than the speaker. Would this look stupid?
I am not sure which is better or if there are any suitable alternatives, please help!
