- May 9, 2015
- 1
- 0
- 0
Hi Everyone
Just looking for some advice from the Audiophile community. I have a Marantz PM6005 amp hooked up to a Roksan Kandy KC1 CD player. Both have RCA or Optical imputs available. I have listened to both and think the Optical is slightly brighter with a a more solid sound stage. I am using an OLD Van Den Hull RCA interconector but a new cheapy Maplin Optical conector. Are there any opions out there on wether a new RCA or upgraded Optical will make much difference, or is it just down to the different quality properties between the Roksan and the Marantz. One more thing Just bought a Atlas Element Integra JP2 that has really opened my ears, what a difference a small cable makes. Hope theres some advice out there. I'm a not masive Audio tech far from it. If it helps to know I am using Q Accustic 2020i speakers with a Rega RP1 turntable, Cambridge Audo premium banana plugs and Bi-wired using Cambridge Symphony 400 cable.
Hope you can help, Many thanks
