First of all I should list the equipment I am talking about I have the following set up in a 5.1 configuration
Denon AVR X6400H
Monitor Audio Gold G5 200 (L&R)
MA G5 250 Centre
MA G5 FX (Rears)
I have had the amp a while but i have only had the speaks a year or so which replaced Tannoy Revolution Signature Revolutions. Audyssey seemed to do a pretty good job at taming the Tannoys in my room but it has been a bit more of a struggle to set up the MAs with a lot more tweaking required. Basically Audyssey seems to want to max out all frequencies above 8KHz which as you can imagine with ribbon tweeters is a very uncomfortable listen. Ear fatigue kicks in after around 2 minutes and my ears feel like when taking off on a plane.
To fix this I tried downloading the MultEQ app where I can add a frquency range filter. I have done this and set the filter to 300Hz so that audeyssey only corrects (Or Should only correct) every below that frequency, leaving everything above it untouched.
I did thi and sent it to the amp, but when I set Audyssey to 'flat' on the amp it seems to ignore the filter and it runs eq correction from 20hz to 20Khz. When I set it to 'Reference' there still seems to be some kind of top end roll off in play.
What I need to do if possible is have audyssey only correct everything below 300Hz and everything above that is completley untouched. Can I do this ?
At the moment 'Flat' is very uncomfortable with immense top end. Reference is dull with the high end rol off. I need it to be somewhere in the middle.
I should add that I have switched all the extras off - Mid range compensation Dynamic volume etc.
Phil
Denon AVR X6400H
MA G5 250 Centre
MA G5 FX (Rears)
Phil
