Currently I have an LG N2R1 NAS box which is a certified DLNA server (also runs squeezebox server and can run Twonky) and all my music rests on it as FLAC files. A Squeezebox Touch is connected to the NAS box over ethernet and plays my FLAC using the Squeezebox Server (pumps it into the Onkyo A9155 amp's analog input).
I am planning to buy an Onkyo TX-NR515 receiver and dispose off my Squeezebox Touch and the A9155, hoping to play FLAC directly on the receiver.
In the user manual for the NR515, in the "Supported Audio File Format" section, there is a note "With remote playback, the AV receiver does not support the following music file formats: FLAC and Ogg Vorbis".
In the "network" section in the manual, there are two sub-headings about "Server Playback" and "Remote Playback", but no explanation of these. There is also a note under "Server Playback" that reads "
Depending on the media server, the AV receiver may notrecognize it, or may not be able to play its music files
Depending on the media server, the AV receiver may not recognize it, or may not be able to play its music files".
Can somebody please explain what the difference is between these two playback modes, and confirm whether my proposed setup will work.
Thanks in advance!
Thanks in advance!
