- Feb 5, 2011
- 83
- 0
- 0
My Quad 44 pre amp has died!
The internal power supply exploded (well, something went bang!) and smoke pored out.
I obviously turned it off and unplugged it.
I can use my Cyrus pre amp instead for now but I really like the Quad sound.
The only issue is the bass is a bit loose but I have kind of decided to put up with that as I think its more a characteristic of my room and will be difficult to fix and balance properly.
Is it worth getting it serviced?
The overall cost of servicing by Quad should be less than what I paid for it but it will then be like new (kind of) perhaps even helping with the bass problem.
I can't spend anything on new equipment at the moment.
