Hi there,
Firstly I will apologise for this being a bit long. I'm newly registered and followed these forums religiously before taking the plunge to buy a Panasonic TX-LZD800 which was delivered on Wednesday 18th Feb. First off, the picture quality of SD is very good, better than expected for SD, and we were blown away with the HD picture quality and the sound is excellent.
However, here is our problem. Everything seemed fine when we were connected to the normal Sky box on Wednesday. Late Thursday afternoon we were connected to Sky HD box and given a limited channel demonstration. On Thursday evening we noticed a black line, like 2 to 3 rows, across three quarters of bottom of screen, which only appeared on SD. The only way to get rid of this was to switch on picture overscan. Called Panasonic Customer Service to report problem and they emphatically said it was definitely not a problem with TV, but the fault lies with the signal coming from Sky HD box. We were also advised NOT to leave the picture overscan on permanently as this will shorten life of TV.
We then contaced Sky who sent another engineer on Sunday evening. Engineer replaced box, now problem with black and white lines across top of screen plus black line now appearing down side of screen. He changed leads and cables but to no avail and said it was likely we have a faulty TV.
Called Panasonic shop where we purchased TV and they said leave picture overscan on permanently as it is designed to compensate for SD, seeing as it is an HD set. He also said all HD TV sets on display in shop have picture overscan set to default. I asked isn't that misleading to the consumer, as the consumer will think that is how the picture would look normally? He said in his training he had never been made aware that leaving the picture overscan on would shorten life of TV. Presently waiting for him to call back.
Called Panasonic Customer Service, and this time was told that we were previously given incorrect information and that it is okay to leave picture overscan on. Here is the interesting bit, which suggests Panasonic are aware of a problem but are choosing to ignore it, he said that sometimes it can happen (i.e. the problem we've encountered), however, he then went on to put the blame straight back onto Sky and their signal.
So, we're now left having paid just over £1000 for a TV, with Panasonic and Sky playing verbal tennis, blaming each other, and we're the innocent consumer stuck in the middle, not quite sure who to believe.
Has anyone else encountered this problem with this particular TV or does anyone know who is right, Panasonic or Sky, because frankly, we're not sure what our consumer rights are in this instance?
Any insight would be appreciated
paws
paws
