I swapped the 33/45 pulley on my Pro-Ject Debut III/SE for the 33/78 version and also added an Ortofon Stylus 78 so that I could play my wife's collection of 78rpm records. Has anyone else had experience of using this kit?
The pulley is easy to swap but the belt is much wider and flatter compared to the original belt. Anyone know why this might be? You can hear it slipping a bit on start-up at 33rpm, or slipping a LOT at 78rpm - so much so that I resorted to giving the platter a spin by hand to get it going before switching on the motor. I also think wow has increased slightly. It's so subtle that I could be imagining it but it doesn't seem as pitch stable as before I did the swap.
Also, are those OM stylii supposed to be that hard to get off? The videos I've seen show a simple pull but mine is so tight it was a real struggle and I was afraid I was going to break the tonearm or pull the cartridge out of alignment, and because you can't do it with the stylus guard on, there's a real danger of damaging the cantilever as your fingertips squeeze the stylus housing. I've swapped back to the OM10 for now, but it was such a tricky business I'm not sure I want to do it again.
Has anyone else tried this conversion and got any thoughts they'd like to share?
