Power conditioner europlugs (cheap)
gasolin
Watching a video about a guy making a hifi system for $ 1000 https://www.youtube.com/watch?v=-lBzREo7dUo
He used a Tributaries T100 AC Power Manager for $ 100 so i wanted to look for one just to se it it's spec and most important the price
Couldn't find one
Thomann.de https://www.thomann.de/gb/power_conditioners.html?oa=pra# i use euro plugs
Something like this
Is there any power conditioners that can be use with this euro plugs for the same price as the onces from thomann let's say 100€
How does they work, i mean they are surpose to delivere even voltage,some have ac noise filter and protection against short circuits, right?
macdiddy
87
that you will find something similar to what you saw in the video, although probably not for $100, maybe add another zero onto the end, that company in the vid makes "conditioners" for the US market only so thats the reason why its so cheap.
But firstly ask yourself why, is there something so wrong with the sound of your system that you need "mains conditioning".
*unknw*
gasolin
Was just interested, many hifi enthusiasts have one, it can make a bit difference and find one used for $100 is not that bad.
The one in the video cost alot more new and generally they are expensive new, except for the onces from thomann.de, but they don't have the right plugs for my system
If it would make a difference to my system i don't know, all i know is that they use to be expensive, so to find one for as little as $100 is okay.
Now i ask about one for 220-240volt and with europlugs for about the same price, since i couldn't find one used for that price.
Not even shure it's possible to find one for that price, don't have to buy one, im just interested in power conditioners,have been that for a long time but never did anything about it since they used to cost 400-500 € or more.
britain4
41
Are you able to solder? (Or do you know someone who can?)
Absolute simplest thing would be to fit a filtered IEC inlet to a box with a double wall socket fitted in it, and can go all the way up to building your own filter circuit if you want
gasolin
Doesn't that sound like a mains block or what ever you call it, something like this https://www.whathifi.com/tacima/cs947/review
britain4
41
Well yes pretty much, just a cheaper way of doing it (although you could go way beyond the Tacima if you wanted)
I think I misunderstood what you’re asking, (the Tacima is a mains conditioner), the product you linked to does appear to be more of a “power manager” with a filter built in. You could still build/buy something for €100 with the same filtering capabilities.
gasolin
Something like this https://goo.gl/dLLAvo
The NA-3900 Power Conditioner and Noise Filter protects against power surges, voltage fluctuations and filters out the unwanted electronic noise. Now, while no filtering device will magically transform the sound or video quality of your gear, the NA-3900 will allow you to obtain the maximum performance from all of your equipment is capable of. Quieter backgrounds behind your music, an improved "ease' of the presentation and glitch-free video are some of the benefits of using the NA-3900.
not just something like this https://goo.gl/PJFGKN
Electro
192
Beware of filtered IEC sockets !
The one in my old Linn Lingo literally exploded filling my room with acrid stinking smoke in seconds, I have never pulled out so many 13 amp plugs in so little time !
Luckily it has a plastic gater on the inside or it would have covered the rest of the electonics in very hot sticky stinking goo.
The Lingo had to go for a service and a new non filtered IEC socket.
britain4
41
I’m sorry I’m still not sure I follow, is the second one just an unfiltered block?
As far as I can tell the first is a filter and surge protector block like a Tacima etc
Ouch that sounds nasty... something to be wary of then... the other way is one of the chassis filters but that’s a bit more soldering and I don’t know if they’re any more reliable...
gasolin
Noise Filter, AC Power Conditioner, Power Filter, Power Purifier
could be something like this (just to take one extreme eample) https://www.ebay.com/itm/Monster-Power-AVS-2000-Pro-power-conditioner-excellent-condition-/222678205773 that makes the power more stable,more noise free and with protection against short curcits
They other one is just a power distributor with some rf filter, connect it to one outlet and you connect it to, in my case, speakers,amp (preamp) cdplayer and turntable. It only has a filter for rf, if it has a protection circut i don't know
https://www.youtube.com/watch?v=Cn1koTr11O4
https://www.youtube.com/watch?v=LyI85XOKzZ4
bonus video https://www.youtube.com/watch?v=UPYHtY0XSiI
britain4
41
Having looked at the innards of that block, it pretty much looks like the same basic design as a Tacima strip, just with a lot more caps and chokes in it - more effective filtering. Theyre both surge protectors. Same with the other well known expensive “rack” size filters, Isotek etc, just a more powerful version of the same thing.
I think the better ones have better spike protection but an RA Superclamp at £20 will give the same effect, not sure if he does Euro ones.
Please someone do correct me if I’m wrong though!
