shadders
Hi,ellisdj said:Shadders all the cables for test are coiled - both sets of wirewold are coiled also
Please for once - just take it for what it is - do the listening tests, listen to what they guy says and listen to the full video without shutting it off because its not technical enough for you.
Its very basic - obviously intended to be - so please just humour us and watch it with decent sound so you can hear it
The claim is, that cables have a characteristic sound. Coiling up a cable will increase the cable inductance significantly compared to its self inductance.
If you believe that cables do sound different, then coiling them will make the test null and void.
With regards to the technical aspects - too much is "hinted" at, with no backup with the very science that they use in that "hint".
Without a paper presented which can be repeated independently, the demonstration is just a marketing exercise.
If you want to believe what is said - then ok - you could take a blind test to confirm your beliefs.
Regards,
Shadders.
