ellisdj said:lindsayt said:Well of course there will be radio frequency noise on your mains supply on top of the 50hz 240 volts. Does he think we're dumb and we don't know that? The live wires feeding your equipment from the nearest sub-station will act like antenna. So what?
If it's an issue for anyone's system buy some £5.86 ferrite rings.
You missed the point Lindseyt he attaches the cable (make shift radio aerial) to the earth socket of the plug. Surely earth should ground the signal so there is no radio signal? Not amplify it and make the signal stronger
You think a ferrite would fix that?
Ellisdj,
If the building was wired correctly, then the DC resistance to ground from the earth pin on a socket should be very low. The same would be true of 50Hz AC, the path to ground should be low impedance - that's how a safety electrical earth works.
This however would not be true of higher frequencies. Wire has inductance, and an earth wire meandering around a building may have appreciable inductance. This means the high frequency impedance to earth may be much higher than the DC resistance - hence the earth pin won't ground HF signals.
.....and yes, a ferrite on the wire close to the device being powered would be a very good way of getting rid of HF noise.
