Power amp recommendation wanted
DeimosNZ
19
Looking for a new power amp but because I live in China getting an audition is tricky (a lot of shops here don't allow a demo with your own equipment).
I have The Music First Audio Class Pre-amp (upgraded to the MK2 version), Sonus Faber Cremona Auditor M Speakers and have just replaced my Metrum Octave Dac with a Chord QUTE Dac. Now looking for a power amp recommendation.
Looking for something suitable for a range of music and leaning a little to the warm side of the fence (tubes are an option).
Any suggestions for a short list?
Ideal price would be about GBP 2k
I see you've got the preamp I'm intending to buy at some stage in nearer future. and I'm intending to mate it with a AM Audio A40 Reference S2 power amp. It costs 2850 Euro + shipping from Italy (they seem not to have any dealer network so the further away from Europe you live the more it'll hurt to have it shipped). so what those 2850 Euro get you?
1. 40W pc into 8 Ohms in pure class A (and that nearly doubles into 4 Ohms and 2 Ohms - feat that only the most stable amps can pull). additionaly this amp is very dynamic which means it can double it's power for short bursts. this is very important quality sice most of the time the amp will not output more than 1 W pc and any additional power is needed for those brief dynamic moments in large scale music. being able to be as dymnamic means the power supply was not compromised.
2. vanishingly low THD at typical listening levels (around 1W output) and gently rising twards rated output power (0.6% THD @ 40W). and also onset of clipping is much less dramatic, which resembles that of a tube amp.
3. even THD levels vs. frequency.
4. the above 2 points mean THD has much more natural behavior. what most typically happens is you get high distortion at low power levels and lowering distortion with rising power and then distortion is sharply rising after the onset of clipping.
5. no global negative feedback which means what THD you can see on the test bench you'll experience listening to music. NFB is a good principle but you must have super fast amp circuitry otherwise the NFB network won't keep up to compare input to output hence won't work correctly. in reality only the amps with the most simple circuitry can benefit from NFB (mostly tube amps).
6. very wide frequency response which means no problems with shrill treble. thanks to high slewing rate there will never be problems with high frequency inter-modulation distortion and high frequency transient saturation - a.k.a. smooth listening.
I don't know how techy you are but all that I just written means you get exceptionally performing amp which will translate into exceptional sound it will create. measure well and sounds poor, no such rule would apply in case of this amp. or any other amps from that bran for that matter.
if you know Italian you can read those two reviews:
http://www.amaudio.it/eng/a40-a6-audioreview237.pdf (even if you don't know Italian at all, like myself, you could take a look at this review to check the graphs, if you can read them)
http://www.amaudio.it/eng/a40references2-audioreview259.pdf
or if you don't know Italian there's a review of a slightly larger brother A-50 Reference on TNT magazine which should be equally useful. in the end the only difference between them is the output power. the smaller one is in no way compromised compared to the bigger brothers. hope this would help you make a decision.
BTW when I'll be buying an amp from AM Audio (and this will be a fact at some stage because I can't see myself finding a better performing amp utilising similar design philosophy which I personally consider to be the right one for designing audio gear) I will be buying blind too. but I won't have any fear in doing so. there's simply no way there can be a mistake choosing this amp.
BTW2 could you share some impressions on using the Music First preamp? and can you describe differences between Octave DAC and Qute (I must admit I'm very intrigued by Metrum's DAC design philosophy as well as Chord's)? Thanks in advance.
Hi Oldric, thanks for the comprehensive response. It certainly gives me something to consider.
Re: The Music First Pre-amp. I am not very good at reviews but I really like it. It has a very transparent presentation and in combination with my other kit I am hearing very nuanced detail I haven’t heard before. It gets rave reviews and I’d certainly recommend it for anyone's shortlist (having said that I bought it second hand and without audition before upgrading it I like it but can't claim it is or isn’t best in class as some reviewers do).
Re: the Metrum. I find it to be a very natural sounding but compared vs my CD player it seems to lose a bit of detail. I bought a SoTM USB Converter which seems to bring the performance up a notch. The Chord hasn’t arrived yet. I bought it on a whim so I am not sure whether it will outlast the Metrum at this stage
Which city are you in? If you are in Shanghai, I would give you several places where you could demo with your own equipments.
