- Aug 10, 2019
- 2,556
- 4
- 0
Happy easter WHFI team! May i take this chance to congratulate you on all of your teams hard work on this forum......! I do have question though, probably for Andrew. Andrew, recently you have solved my questions to the PMC OB1 and CB6 speaker setup to which i have fully complied and truely thank you... (ref speaker wiring set up). I am now in the process to back up this system with using the new TB2i's as rear surrounds and i'm sure they will blend in fine. My thoughts on a subwoofer to compliment this set up is slightly clouded. Although I'm sure you would say to use a TLE1, would you also think of using another sub like the SVS PC-ultra cylinder, and of course i can appreciate your lack of honesty if you haven't had any experience of listening to it. I do like the idea of having good bass extension for music and especially movies with out having to use a large foot print within my living room area, which is why the SVS seems a good option , but i also know the TLE1 can also fit my criteria because that also has a foot print smaller than most, albeit more expensive. Having read that quantity of bass is not necessarily important, but quality is... do you think my choice could be a wrong one in this speaker set up and should i stick to the TLE1 ? Regards Tony.
