plastic penguin said:
Electro said:
Vortex160 said:
Electro said:
As already posted the foam panel in the end of the transmission line of the DB1+ is not a bung that should be removed !
If you want more bass you can either use a more powerful amp because believe me if you hear a pair of these on the end of a amp like the Bryston 4bsst or similar, bass is not in short supply :exmark: , or you could add a suitable sub to reinforce the lower frequencies.
I love the little DB1's they are a fantastic speakers that are capable of much more that a lot of people imagine 🙂
more power hmmm.. as a matter of fact i am looking for an integrated for my db1s but dont have the dough for a bryston.
max budget is $1500 , i was thinking about the nad 375bee (150 watts of pure nad power).
do you think the nad will be a good match for the pmcs ?
Yes that Nad should do the job
Others to consider would be the XTZ Class A D3 Integrated amp
http://www.audiosanctum.co.uk/Integrated-Amplifiers/XTZ-Class-A-100-D3-Integrated-Stereo-Amplifier-Black.html
Or maybe the Harman Kardon HK 990 .
http://www.hometheaterhifi.com/integrated-amplifiers/1418-harman-kardon-hk-990-stereo-integrated-amplifier-with-digital-room-correction-and-dual-subwoofer-bass-management-part-iii.html
Or possibly something from Emotiva .
http://shop.emotiva.com/
The great thing about the PMC DB1's is they get better and better as you upgrade the rest of the system but will work well with almost anything .
Roksan and Creek are also worth looking at. Also the higher end Arcams.
Would the creek evo 2 do justice to the db1s considering its 60 watts ?
Ive heard db1s can handle alot more power , my basement is fairly large, so need max quality at loud volumes.
No experience with creek neither roksan
ive heard nad gear before ,it surely does go loud without much difficulty and the bass is overwhelming in a goood way.
Also these days a little coloration doesnt hurt, given the quality of poorly encoded lossless files.Almost everything that i listen to is in flac.
Dacs reduce jitter but can they reduce harsness?
The Evo2 is 85 watts RMS, and a very gutsy little amp. After having it on dem I've a real zeal for the Creek.
TBH, although the Nad has more than enough power to drive the DB1is, I don't think it'll be tonally as good as the Creek or Roksan Kandy, or even the Naim Nait 5i. The Nads tend to be very warm in presentation. Likewise the DB1is are fairly smooth, and adding warm and smooth can rob the soundstage of life.
I agree with you , tonaly naim and creek are superior than nad. I have heard naim 5i with some proac bookshelveshad an amazing depth ,detail but the dealer did point out that naim gear is revealing as any high end component.I believe he gave an example of a ferrari not performing well on a track which had bumps and cracks compared to bmw.
My gripe is that most of the stuff i listen to is poorly encoded .
i ocassionally buy tracks from juno, flac or wav mostly ...
i believe one tends benefit from the extra warmth or smoothness when listening to repetitve stuff , im not talking about trance , house music etc , more like tape loops , feild recordings , experimental ambient kinda stuff..
would an upsampling dac do any good in improving the source?
