Please help : Ideas on best new model AV Receiver Sub £800 in Silver
Yes, I know Silver cuts it down but I have got Cambridge Audio kit and want to upgrade my CA 540R version 1. I hope a 640R upgrade or 740R may be out soon.
Any help much appreciated.
A number of us have opted for the Yamaha RX-V3800 (only available in silver) ÿ- maybe not the best scaling, but if you don't need it, superb sound. ÿThis originally retailed at something like £1400. ÿHiFix still have a few at £749.99 (according to their website). ÿI am thrilled with mine and it definitely merits checking out alongside the end of the line Onkyos and Denons, rather than opting for lower-spec new models.
Bemused:
Don't forget the ubiquitous Onkyo TX-SR875 or the TX-NR905. I can personally vouch for the 875 being a damn fine amp.
I think it depends what's more important for you music (tv+stereo) or picture? I find CA AV receivers lacking the picture options if you compare them to Denon 1909 for example.. Regarding the music, I've never compared CA with others so don't know although I think if you care about stereo you should have separate stereo amp for that and this is where CA 740/840 would be very good choice.
I think the best option is to buy an AV Receiver that does picture part well + has preouts so you can connect stereo amp if you have one or if you buy one in the future (unless you have a separate system for stereo)
But anyway answering you question. I found Pioneer LX51 interesting choice (less than 800£) because it has preouts and upscales both analog and HDMI sources. Hopefully WHF review wil come soon.
And if you don't mind the look I'm sure Onkyo 875 would be a good choice as well.
Sorreltiger:A number of us have opted for the Yamaha RX-V3800 (only available in silver) - maybe not the best scaling, but if you don't need it, superb sound.
Does it upscale both analog and HDMI sources?
The Yamaha only passes through an HDMI input, but upscales analogue. ÿit uses an Anchor bay chip - supposedly better than the Faroudja, but not as good as the Reon. ÿAs I said before, it may not be the best scaler, but you're getting £1400 of sound quality for less than £800 at present. ÿIt's a pity that it was never reviewed by What Hi-Fi, but others are prepared to recommend it. ÿI believe that some of the HiFix staff have chosen it for their home set-up. ÿThe new generation of Yamaha receivers have had fantastic reviews, of course.
stuart123:Richer Sounds are selling the Denon 2808 in silver for £499. Was orig £900
Why every time I see a deal it's in silver.. damn damn..
