Pioneer amps with THX ultra 2 plus
  • Start date
Deleted member 2457
I never knew Pioneer stopped producing THX ultra 2 plus amps with the Pioneer sc-lx88. The Pioneer sc-lx87 seems to be the last one that had it!
buzz_lightclick
That is correct (mentioned on another thread over the weekend). Atmos came in with the 88 but THX went out, presumably a cost saving measure?
gel said:
And now they are going to cost £2500!
That's because it has extra 2 channels of amplification (11 channels) in comparison to its flagship predecessor (9 channels in LX89).
Also, Onkyo's TX-NR3030 with 11 channels of amplification was the same price. Onkyo will ensure that Pioneer does not undercut its offering.
Deleted member 2457
Cheers.
Does the Onkyo have THX ultra 2 plus?
Onkyos are THX Select 2 certified.
Previous model:
http://www.uk.onkyo.com/en/products/tx-nr3030-117903.html
New model:
http://www.uk.onkyo.com/en/products/tx-rz3100-132671.html
Bear in mind that for THX to work, every single component in the chain (blu ray player, AV receiver, speakers and TV) need to be THX certified as far as I'm aware.
Deleted member 2457
I thought it guaranteed the amp was made to a high standard too?
Deleted member 2457
Is there any manufacturer left that does THX ultra 2 plus then? Cheers.
spiny norman
293
gel said:
Really?
Yup, and you have to play really loud to reach the reference level required.
The spec requires 85dB at '0' volume setting on a THX Ultra receiver, with 20dB of dynamic headroom. For those who are forced to play at lower level (such as most of us not viewing in a soundproof bunker), THX Loudness Plus is built in to compensate for detail, spatial information, etc lost when you dial the volume down.
Deleted member 2457
spiny norman said:
gel said:
Really?
spiny norman
293
bigboss said:
No, it doesn't. It simply means that it meets THX specifications which Spiny Norman alludes to.
The cynic (who, me?) might say that it just means the manufacturer has paid THX to test and certify the product, and whatever ongoing licence fees may be involved.
That's not to say there aren't products out there that don't meet or exceed the THX requirements, but the manufacturer chooses not to spend the money having them certified.
Deleted member 2457
£2500. Not too bad.
https://www.audiovisualonline.co.uk/product/32054/onkyo-pr-rz5100-black-11-2-channel-av-processor/
Frank Harvey
567
