PC Sound Card with Digital out put
Hi
Can anybody help me to find a Sound card that has Coaxial and/or Optical Digital Audio Output , I don't need surround capability. I am going to use it with HK3490 2.1 Ch and Audio Monitor BR2.My web searching experience shows that I am looking for a very rare product....
Asus Xonar - have a pci or pci-e range from around £30 to £100
thank you every one,
@JohnDuncan : any of them
at this point I'm looking for cheapest one because I think it doesn't affect on quality with digital coding system .Am I right?
@edsib1 :Thank you man, I think finally I have to go with Xonar but I am not sure if that is compatible with Windows 7
I think they all work with windows 7. But see for yourself.
Pick ur product - audio card, series - pci or pci-e and model and then check drivers are available with the link below.
http://support.asus.com/download/download.aspx?SLanguage=en-us
@edsib1 : I just found amazing thing which called SPDIF card that has only two outputs like Gigabyte Coaxial RCA SPDIF Audio Bracket on ebay , I am researching on this right now ....I will post again about the result, Thank you for the link
Dose anybody hear about "Musiland Monitor 01 US, USB sound card, USB2.0" ??
[/b]
