Panasonic tx32lxd70 or lxd700?
billybodger
10
After much head scratching (and getting somewhat confused) i decided to get a tx32lxd700 as it seemed to be the best 32" lcd around at the moment. But on looking at the sepc of the lxd70 i see that the only difference between the 2 is that the lxd700 has better sound, an sd card reader and a split screen mode or have i missed something? If the picture quality is the same and as i dont need the last 2 fetures, would i be better of saving the £150 difference and spending it on a cheep av system? ( such as the Sony htddw890 for £209 or a yamaha av61 system) Any help will be much aprciated, its all to confuseing !
Lots of discussion on this topic in the past on these forums. Put either of the model numbers into the search box at the top of this page and you'll get a listing of all the posts.
