Panasonic TX-40CS520 (B)?
graham.k
Looking for a small LCD for daughters bedroom and came across this one, http://www.whathifi.com/panasonic/tx-40cs520/review seems to be what I'm after but when trying to buy one I can only find a TX-40CS520B. Can anyone tell me if the "B" version is the same as the one in the review? If I do a search on the What HiFi web site it looks like there are two versions.
Any help appreciated,
thanks, Graham.
RodhasGibson
191
9
18,595
graham.k said:
thanks, Graham.
I think you'll find that B means it's in Black.In some markets I think they also do it in Silver.
strapped for cash
417
The "B" in Panasonic model numbers refers to "British."
It's the same as the reviewed model. It's also the one you want (assuming you decdide to buy this particular television), since it'll have a Freeview tuner.
