kena:
Rock Man:Thanks for all the replies, can this be done without a 'harmony' remote?
If by that you mean any remote the answer is no. It can be done with a Harmony,One for all Kameleon, or Philips Pronto , or a bought remote that you can return or keep . the hex codes can also be sent via IR on a PDA. Others may be possible but I gve up my search when I found the CCF file which I could use on my Pronto.
What i meant - not very clear on my part, sorry. Is do you need a seperate remote or can this region free hack be done from the Panny remote?
