- Aug 10, 2019
- 2,556
- 4
- 0
Looking for help and advice...
My Dad's recently bought a Panasonic VT30 and a Yamaha YSP-2200 to go with it. The panasonic has been great although everytime you switch it on it defaults to TV instead of HDMI1 which is annoying, but the main problem has been the Yamaha and for the life of me I can't get it working well. I connected the SKY+HD box in the same way I connect it to my amp which is feeding both a HDMI and optical connection from the box to the amp however on the YSP all the sound goes via the HDMI and I do know which setting to change in the setup menu to tell it to use optical. Following some other discussions on the forum I changed the setup to run a HDMI from the Sky box to the tv and an optical to the YSP only and evetnually managed to get this to work but it doesn't seem a neat way of doing it and everytime I switch away from Sky and then back again the channel on the YSP doesn't go with it - I switch to TV to view its online content which for some reason switches the YSP to TV aswell but then when you go back to HDMI1 the view Sky the YSP channel stays on TV and doesn't switch back to the optical channel. All of this means that you can't control both the pitcure and sound from the YSP instead you need the TV control to switch the AV port and the YSP remote to select the matching sound channel as well as the Sky remote to use Sky!
So my question is....
1. How do you connect a Sky+HD box to the YSP? Do you use both a HDMI and optical cable? If so how do you tell it to send the sound via optical?
2. When you view TV content how do you get the YSP to change back to the appropriate output channel when you move to Sky or another device?
3. When I add a Blu-ray player to the mix what is the best way of setting that up to work with this setup? I'm assuming this is easy as it sends the sound and picutre via HDMI.
4. Can the YSP work like a normal amplifier and take all my feeds and coonect top the TV via a single HDMI cable thereby doing away with the TV remote which I only really need to change AV channels?
Don't know why I'm finding this so hard especially when all the reviews you read are saying how easy it is to set up :help:
Is it me or is the manual that comes with this unreadable?
Kenny
Kenny
