any recommendations on speakers to pair with Marantz CD player and Rega Brio amp? looking for the best but not too good considering the CD player and amp isn't exactly top end!
You don't need powered speakers if you already have an amplifier. The KEFs are not powered so will not have any sort of inputs.my budget would be £1000 and my room is small roughly 350cm x 300cm. I have the option of the rega brio amp or my portable mojo2 amp, which would you use for this set up? Im not sure is it worth buying speakers at £1000 considering the rest of the set-up? something quite compact would be nice I reckon! I also have a rega rp1 turntable does the key speakers have a phono input or does the rp1 have a built in phono stage or external so that I can play vinyl through the speakers if I was to choose kef meta
