DIB:
A bit of advice please gentlemen.
As you can see, I have a 2M Red. Well at least I did! Can't believe it but the diamond tip is well and truly goosed. Was working fine last night, came to use it tonight, gave it a little clean up with my stylus brush and its bloody gone on me.
My question is this. If I remove the 2M Red stylus can I replace it with a 2M Blue stylus, without the need for buying the full 2M Blue cartridge? 2M Blue stylus £90, 2M Blue Cartridge £150+. Big difference.
Thanks for any advice you can give.
Yes, just buy the stylus- take the 2M stylus out (it slides out with very little force) & replace it with the 2M blue stylus! presto! The body of both cartridges are the same- the difference is the stylus (2M red is elliptical and the 2M blue is nude elliptical) Hope this helps
