optical cable questions.
farawaydave
60
Being an avid convert to the sonos system.(2 play 3's upstairs,2 play 5's and a sonos sub downstairs) I am now on the verge of buying the playbar.My panasonic TH50pz80 does not have a optical out so i'm going to have to use a switch of some kind and connect it direct from skyhd box and direct to my panny bd player(cyd stuff looks interesting) I have little knowledge of toslinks,switces etc so would welcome some advice bearing in mind I need 2. cost is a cosideration but value for money more so.
How many products do you have running to your TV? It can be done without to much drama but there might be a few things to look out for depending on what you are running.
Drop a reply with an equipment list and we can see if we can work out how your can get all the audio you want to the playbar.
The Panasonic TH-50PZ80 has an optical out on the rear panel.
It is labelled Digital Audio Out just above the component in.
