Onkyo TX-NR708 OR Pioneer SC-LX81
Hi all
In need of advice. I own the following:
Onkyo TX-NR708
Pioneer SC-LX81
B&W 686,685,HTM62,ASW608
Monitor Audio Silver RX-6, RSW12,Silver RSFX
I have one simple question which combination of the lot would give me the best sound. I can't try them out as some of the system is in a flat that I rent out. Please advise.
Thanks for all your help
Chewy
29
My only advice is get them out of the flat that you rent out - as a landload you are legally obliged to maintain any equipment left for the use of the tenant.
Hence if the reciever blows up, you will be obliged to replace it with a new one.
As for your own listening combination - I would go for the Pioneer with the Monitor Audio's personally, but as with all things audio, it comes down to personal preference.
Hey
Thanks Chewy. Just a couple of things, the Pioneer I bought in 2008/2009 and then the Onkyo I bought in 2010. Is there much of a difference in terms of technology and power between the two? Would the Onkyo be powerful enough for the Monitor Audio speakers?
I really appreciate your help. I will take out the system when the contract comes up in October.
Thanks mate
Hey guys I will take your advice. I have the Pioneer now at the moment.
I have plugged Sky TV into input 2(HDMI) and it works fine. Problem is the BD which I used HDMI to BD HDMI port is not working nor is my apple tv which I plugged into HDMI input 1.
Does anyone know what I should do. I am loosing what hair I have left on my head
