Onkyo 606 sound settings
iangarrett
I have been having some trouble with my set up lately. For my HD Sat play back the amp is locked in Direct mode. I can't find this in the menu's to allow me to change this setting. Can anyone let me know how I can change this please..???
gingersmarty
58
Hi
If you are talking about pure audio it should revert to the previous setting by pressing the button on the receiver again failing that......
* To reset the AV receiver to its factory defaults, turn
it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button (see
page 96).
hope this helps
chrisup
49
Hi
I have an Onkyo 905 and i have buttons that say Stereo, Pure A & Direct and they are often used for music. On my remote if I press Surround I can change a broadcast into 5.1 using a choice of Dolby, DTS and THX settings. Experiment with your settings and see what you prefer obviously Dolby HD and DTS HD sources should sound incredible.
Best Wishes
Chris
