Onkyo 606 OSD
Hi guys
I have just bought the onkyo 606 and Kef 5005.2 spearkers. While setting up the Onkyo with mic to calibrate the speakers the manual says there should be a on tv dislay with all the settings but i dont get anything on.
onkyo is coonected via MONITOR OUT with component cable. It passes through all other types of video like PS3 or DVD but no setup OSD. Help.
Ravey Gravey Davy
225
I had the same problem with the 2005.2 but I just carried on with the Onkyo display to set up.Just setting off to get the Panny TH37PX80B -if it persists after that I shall have to think about doing something about it.
[quote user="Andrew Everard"]
I'm at a loss on this one. How are your other sources connected to the receiver?
[/quote]
ps3 via HDMI
sat box via component
Could it be i need HDMI TV to get the OSD for onkyo ?
Hi there kunal_x,
same problem here. I tried composite connection as well as S-video. Went to the setup menu (via the LCD menu) to check whether OSD is set correct. As far as I can see it is. Did anybody maybe reply that the OSD is only available through the HDMI output (which I'm not using (yet))?
regards
[quote user="dutch_member"]
Hi there kunal_x,
regards
[/quote]
ermmmm. Where in the LCD menu on onkyo is the OSD setup. i just couldnt find it!
VoodooDoctor
81
Have you switched off HDMI output in the setup menus? That may help. I think the OSD option in the menus is for things like volume display and is separate from the setup display (feel free to prove me wrong).
[quote user="VoodooDoctor"]Have you switched off HDMI output in the setup menus? That may help. I think the OSD option in the menus is for things like volume display and is separate from the setup display (feel free to prove me wrong).[/quote]
Hmm interesting i will have to try this. could you tell me where in the setup i can switch off the hdmi output. sorry i searched the manual and onkyo lcd setup cant find it, I know i being dumb somewhere ; i just cant find anywhre to control the output options.
kunal_x:dutch_member:
Hi there kunal_x,
regards
No need to look. I can confirm that the OSD is only available over HDMI.
regards
