Olive 04HD analogue or digital output?
I did look at the other forum but a quick search didn't reveal anything. I accept your point though about the level of sensitivity required. You're also right that while I'm engaging in this I'm not enjoying the music. Your sign off says it all.
omnibeard
27
I honestly didn't mean to be obtuse - it's just if something sounds better to you, then effectively it is better. Do you really need to know why?
Gent's
I am using a Olive 04 HD with Cyrus 8 Qx (and power supply PSX-R) - and to go digital out from the Olive 04HD with outboard DAC does give a noticable improvement in detail and more layered at the same time the sound is more relaxed .
Mind you this was first notacible after a decent Powerblock and P cables :) and for the ones not willing to belief just try and be astouned what it can do ...
Check out CP audio for a top Powerblock and cables - this guy really went the whole 10 Yrd's and his product are owesome , any by way the analog connection was with Fadel Art IC and these are good quality IC's still Atlas Ascent Dig. gave a better performance
Speakers are B&W 805 Diamoind and Cables again Atlas Ascent MK II
Enjoy
