Deleted member 188516
No they can't. Just found the manual online and it's bare wire only as you stated.
qed 79 strand as rick suggested then...
Like this?Just to clarify the 79 strand cables are unbranded.
Like this?
No speaker cables do not have to be the same length, you might find a time where you can move speakers so they are equidistant from the amp, and then you're stuffed with one short piece of speaker cable that is useless.....Just realised I'd forgotten to ask, is it important to buy the same length of cable for each speaker (one is much closer to the amp)?
