newbie cofused
have just got all new kit together and have a few questions about cables
system is as follows
sony 40x3000 onkyo 875 kef iq7(front) kef iq5(rear) kef iq6 sky + denon 1940 sony bdp300
do i need v1.3 hdmi cables or v1.1 ok?
do i need to run coax/ optical between dvd/blu ray and reciver for audio ?
will i benifit from bi wiring front speakers ?
what is the best way to connect sky + is it worth converting to component video ?
can any 1 recommend a good make and add any other tips on how 2 get the best out off my system
thanks
Hi there - replies for the answers I know:
[quote user="brewiex1"]do i need v1.3 hdmi cables or v1.1 ok?[/quote]
Yes, get one for the Blu-Ray player since it outputs deep colour and your TV can accept this. DVD player only has 1.1 output so no need for a certified 1.3 cable for this.
[quote user="brewiex1"]do i need to run coax/ opticalÿbetween dvd/blu ray and reciver for audio ?[/quote]
No, both the Denon and Sony can output sound via the HDMI so just hook these both to your Onkyo.
[quote user="brewiex1"]what is the best way to connect sky + is it worth converting to component videoÿ?[/quote]
Probably not worth the hassle from what I've gathered from other posts. Just hook the RGB Scart direct to your TV and then connect standard RCA phono leads to your amp (or optical cable if it has this, but I don't think the Sky+ box does).
Hope this helps!
