New speaker recommendations
stumpy66
10
I am looking for new speakers for my NAD C521BEE cdp & NAD C320BEE AMP, i am currently using Tannoy Mercury MX3 floorstanders but they seem a bit bright and tiring after a while. I dont mind buying secondhand, and ideally they need to be able to sit close to a back wall. Standmounts or floorstanders althought the room is only about 3.5m x 6m with the speakers firing across the shortest length. Gotham speaker cable/interconnect. Budget up to £300
Any help appreciated
If it were me, and going for 2nd hand i'd be looking at either B&W 602 S2's or the B&W 602 S3's as theyre great standmount speakers, fantastic bass, clear and taut midrange and crisp treble. Theyre forward firing also so will be fine to sit close to a wall. You'll be able to find good examples on Ebay
I had these a few months back and had them partnered with Atacama SE24 speakers stands. You could also look at the Atacama SE20, Nexus 5 or 6 stands as well on Ebay. Ideal as well for filling with Atabites which i found to give a much better sound over sharp sand!
hi
ive just got some monitor audio rs1's and they look superb , i still have to listen to them yet but i will be connecting them to nad gear (c320bee/c521bee)
[quote user="beachBOYken"]
hi
[/quote]Let me know how you find them, will you be placing yours close to the wall?
[quote user="d_a_n1979"]If it were me, and going for 2nd hand i'd be looking at either B&W 602 S2's or the B&W 602 S3's as theyre great standmount speakers, fantastic bass, clear and taut midrange and crisp treble. Theyre forward firing also so will be fine to sit close to a wall. You'll be able to find good examples on Ebay
I had these a few months back and had them partnered with Atacama SE24 speakers stands. You could also look at the Atacama SE20, Nexus 5 or 6 stands as well on Ebay. Ideal as well for filling with Atabites which i found to give a much better sound over sharp sand![/quote]
Thanks, will have a look on ebay
[quote user="stumpy66"][quote user="beachBOYken"]
hi
[/quote]Let me know how you find them, will you be placing yours close to the wall?[/quote]
they are fairly close but i might try the positioning from my other post on this page , i will let you know what there like
well after trying my rs1's , im very pleased i find that i dont have to turn my volume up as much as i used to on my wharfedale 9.1s
im also aware that they need a lenthy run in period it says 30hrs in the manuel so i can expect even greater things with them
overall to me they are a big improvement from my wharfedales
cheers
