Hi all. Im thinking of getting a new stereo system and woulkd like some advice if possible.
Budget is 600-700 may be able to push to 800 if needed.
Its for a medium sized living room. I have a Optoma HD141x projector for my main screen projected stright onto wall. And I currently have a Rotel RA-931 & Eltax Liberty 3+, bi-wired on speaker stands with van damme blue studio cable with gold plated banana plugs for connectors. I have a wooden floor and neighbours underneath so dont often get to play loud but would like to get abit ravey and loud every now and then. I sit right at the back of the room, which is the reason im not sure about a surround setup as i have no room behind me. I could move forward into the room if it was worth it for the surround experience.
I mainly play dance type music (oldskool and rave from the 90s) but i also like abit of classical now and then so im looking for good bass but with abit of clarity aswell. I also use the setup for TV and games awell. All sound comes from the PC via an optical spdif not toslink.
I want to stick with just Stereo for now but would consider a Surround Amp for future proofing. (Do surround sound amps deliver on the Stereo level?)
For the Amp Ive been looking at the Marantz PM6005 at about 300 quid. And on the Surround side a Pioneer VSX-930 or maybe a Yamaha with Atmos.
Speaker wise I love Tannoys for their Low Level Bass and have been looking at the V4i's. But alot of review are saying the Q Acoustics 2050i are bang on for the money 300 ish. Also been looking at the Cambridge Audio Aero 6's and the MA MR4 or MR6's.
So yeah if anyone has any recommendations or info regard the budget end of the scale I will appreciate any info. Many Thanks.
