Nevo C3 & One 4 All Xsight Touch
Looks like these are both the same remote inc spec.
Both companies owned by Universal Electronics.
Only diff I can see is the Nevo is around £200 and the Xsight Touch £100
Any body got any further information??
Hi Sammy
You're right. Nevo and Xsight are the same products. Nevo is a custom install brand ie. if you get someone to install a home cinema system for you at home they might give you a Nevo remote but you can't buy it in the shops. One For All Xsight is the retail brand, so if you're looking for a universal remote control that's the one to look out for. The Xsight Touch just got a five star award from What Hi Fi and you can buy it on amazon.co.uk for under £100.
Julien
