- Aug 10, 2019
- 2,556
- 5
- 0
Hi
My 5 yr old Palm PDA is starting to go on the blink (like a 5min battery life now!) and while I was going to upgrade it eventually, the decision may need to be made sooner rather than later. There's still some PDAs out there on the market (e.g., the HP iPaqs) but it seems like most people are either choosing to go for smart phones now or, god forbid, reverting to filofaxes to keep themselves organised.
My mobile's not due for renewal for another 5 months which will be well past my PDAs life expectancy I fear, and even then I'm not sure I'd want to switch from my £8 a month tariff (it's an old one) to a £30+ one to get an iphone, as good as they are. My 3 yr old ipod 5th gen could also do with a renewal, so I was wondering whether the ipod Touch 32Gb might be a good solution? Does it have the ability to be used as a normal diary as well as making task lists etc. which you would find with a normal PDA? (I know it would replace the ipod quite well!).
Any thoughts appreciated.
Tim
Tim
