Need help with speaker posts on Audiolab 8000p
lewis hurlin
34
I have recently bought an Audiolab 8000p which is bi amped with an older 8000a the trouble is the new amplifier has those horrible binsing post on it I am wanting to use bannana plugs which I use as connectors on the other ends of the speaker cables help...
All sugestions greatfully appreciated
System Aduiolab 8000a mk2 and new 8000p , Arcam CD73T , QED aniversery XT silver Bi wire cbale and Chord Crimson interconnects
The banana plugs will work fine on your Audiolab.
Just ease out the plastic blanks that cover the sockets.
(The blanks are there to prevent people from using banana plugs. You might take your speaker leads and shove the banana plugs into some Euro style mains sockets by mistake then lick the other ends. Everyone does it.)
they fit really tightly in the audiolab took me ages with a pair of really sharp pointed pliers - ususally use a scaple/craft knife but you can't get to the because of the moulded colour bits - don't push on them though as they will go further is making it even harder
