Need a new av amp
Which av amp should i buy? Is Onkyo the only brand to consider? I have two budgets One if i buy before March - £500 Or £1000 If i wait? Any ideas?
Needs a decent set of speakers.... what have you been looking at so far and whats your budget for the speakers.
I would say Onkyo are your best bet, can't put a foot wrong at the moment!
so do i and the onkyo's look good with awards and recomendations from what hifi ! and which ! in a range of price tags, but you didn't mention what your linking it up to ? i want 1 that i can run my pc through to and i'm not sure the onkyo's can do this .but is't a question i've put to the forum so if you need pc connectivity as well you can look and see if i get a reply there.plus are you hd ? the onkyo's can do this, i think some can upscale
and 500 should get there unless you've a massive space to fill with sound ,or the rest of your system is kicka*se in which case you may need the full 1000 for the onkyo tx-sr875.
still which ever you go for enjoy .
mark
mate i just got the onkyo £400 amp and its paired with 4 b&w 685s and b$w sub and front sounds unbelievable . paired with full hd 60 in lg plasma and blu ray and sky hd .
