Hi all, first time posting so apologies if this is in the wrong place, I'll try to be as detailed as possible.
I have a Cyrus 6XP amp paired with some Revel Concerta 2 speakers. The inputs are a Cyrus CD player and Rega P3 turntable. The speakers and turntable are relatively new and I've been using them regularly with no issues and great sound.
I took delivery of a NAD c 658 streamer today. I've set it up as an input to the Cyrus amp so I have digital options for streaming. Unfortunately whenever I switch to the NAD input there is a loud hum coming from the speakers. I've tried changing the input, made sure all of the connections are sound. I've tried the altering the volume on the NAD and on the Cyrus but nothing seems to fix it. The hum is only affected if I change the volume on the Cyrus amp so can only be eliminated if I turn the amp right down which makes the music inaudible. If I turn the NAD up significantly I get crackle from the speakers too.
Does anybody have any suggestions as to what might be causing it? Any help appreciated.
Thanks,
Thanks,
