Kevinz:
Can anyone please help on this? Saw the review for ATC SCM11, and as it is mentioned in the review, it suggest use amp with at least 100w/channel.
For MXI2080, it has only 80w/channel, however it looks MUCH better than Roksan K2, and this is the only reason keep me away from the K2. Another thing is ATC SCM11 is bigger than SCM 7,but someone said the smaller speaker is even hard to drive, not sure if MXI2080 can handle it well.
Any comments will be appreciated.
Hi KevinZ
The MXI2080 and K2 amplifiers have power which is sufficiently potent to work with ATC's SCM7 or SCM11 models. As long as you are not intending to play the amplifiers constantly at disco like levels than it will be fine.
For the last few years now i have often used a modestly priced 50w/ch integrated amplifier to demonstrate ATC SCM7, SCM11, SCM19 and SCM40 speakers. It is not the greatest amplifier in terms of the quality of power or performance however this amplifier has happily got on with it's job without suffering from a nervous breakdown or a heart attack.
The amplifier driving the various ATC speakers has quite happily filled the store with sound without reaching clipping.
I have used and have customers that use the classic NAD 3020 amplifier which is around 20w/h with ATC speakers and yet again no issues about lack of power, performance or breakdowns of the 3020 or the ATC speakers.
The ATC's low distortion levels will allow your components to breathe and therefore allow their qualities to shine through.
If you can afford and can accomodate the SCM11's than go for it as they are significantly better than the SCM7's.
Btw, when it is done properly than the lower it distorts the more natural it sounds.
Rick @ Musicraft
