The router is downstairs so that would be an issue, right?If it's via WiFi could you connect an ethernet cable instead?
Ok, cheers.Well ideally you'd be able to connect via Ethernet but if a direct connection can't be made, homeplugs may provide a more stable connection than wifi
Thanks bb.Make sure the latest firmware is installed. Also, try to reset your TV.
How to reset my Samsung TV
FAQ for Samsung television. Find more about How to reset my Samsung TVwith Samsung Support.www.samsung.com
Won’t let me reset the TV either or do a firmware update.Reset the TV and check again.
Request remote support then. It just needs resetting.Won’t let me reset the TV either or do a firmware update.
Turned it off YouTube and onto the Amazon Fire stick and it now lets me do the update to firmware and factory reset. Cheers.Request remote support then. It just needs resetting.
In my Sony, I get the option to restart the TV by long pressing the power button.
Cheers for the advice.sounds that connecting to wi fi through router works But how about a direct cable link instead of wi fi ( if it able to do that? My Shark RF OPENSPOT is not wif fi so direct cable from router. ( i be very surprised if anyone here knows what that is ) my notrmal connection PLASMA TV is through Amazon prime HDMI . Pansonic does not support the Plasma anymore
I'm assuming your issue has been sorted?Turned it off YouTube and onto the Amazon Fire stick and it now lets me do the update to firmware and factory reset. Cheers.
Yes, I think so thanks to you bb.I'm assuming your issue has been sorted?
Does it happen with any other apps? How are you watching YouTube? Through Samsung app or via Firestick or similar device?Sometimes my Samsung loses its picture and just goes black, you can still hear the sound though, then I have to power off and then back on again and it’s sorted. Any ideas? It’s when I am watching YouTube it happens.
Just YouTube it’s the only thing I watch on it. The Samsung app on the TV. Been on the phone with Samsung and John Lewis all day. In the end Samsung took control of the TV and reloaded the apps again and deleted some cookies. John Lewis was going to do a repair but then worked out it was a software issue so I had to go back to Samsung again.Does it happen with any other apps? How are you watching YouTube? Through Samsung app or via Firestick or similar device?
