My home cinema pics
Status
Not open for further replies.
gel said:
bigboss said:
Thanks El Hefe! :)
Son_of_SJ is coming tomorrow to check my system out.
What did he think to it?
Best for him to answer that! :)
He liked the projector, but didn't think Atmos offered much beyond his 11.1 (although Atmos is a true encoded format which you will lose with a non-Atmos configuration, and 11.1 is a pseudo configuration).
Deleted member 2457
bigboss said:
gel said:
bigboss said:
Thanks El Hefe! :)
Ah okay, I thought he might like the projector.
ellisdj
377
Projectors are something else - needs to be proper dark though, with the correct stuff on the walls - tomb like - this has nothing to do with the screen its to do with light reflections from the surfaces around the screen. Learnt the importance of this the weekend just gone
I am putting this theory into practive atm for my Plasma as I cant have a PJ because of my system setup. I am hoping to improve the performance of it to the standard I experienced last weekend just on a smaller scale
Shame because PJ's are incredible but you cant have everything sadly
Deleted member 2457
Agreed. If you create the right environment you can get more out of your TV. My old home cinema local shop taught me that with their setup. No windows and lights that went right down and on the wall too - looked awesome!
"It has nothing to do with the screen" isn't true at all. Draper ReAct 2.1 has a grey silver screen which boosts contrast and rejects ambient light far more effectively.
Son_of_SJ will testify how the picture looked with curtains open as well as all 8 ceiling spotlights on.
ellisdj
377
That screen will no doubt help, but I mean what you do to the room so that even when completely blacked out there is no light reflecting at all. Most people would not do this in the home but the effect it has cant be understated. I have seen great projectors look good - but this is a different league to that / anything I have ever seen before and apparenly its because of the treatment to the room.
It is to do with contrast though your right there
You don't need a batcave at all to enjoy a projector. My room's walls are all white. Reflected light from the walls doesn't hinder viewing experience. Think of Draper ReAct as a plasma. You can enjoy it even in ambient light. The screen is the key.
ellisdj
377
BB without the correct stuff on the walls and ceilings the room will never fully blacken out. This is the same even for.my tv, in fact my tv illuminates both side walls really badly. I had never noticed this until now, i didnt realise it had an effect.
For PJ its about stopping overspill apparently.
I have the stuff coming today today to test out. I doubt you would want to do it anyway.
I am in 2 minds and i am hardcore :)
ellisdj
377
That is what i thought as well - I think the systems I saw they were using a different ratio to oversize the image and remove the black bars top and bottom so you had a full screen not letter boxed. Worked wonderfully with no negative effects.
This is likely the cause of the overspill - in your picture you have not done that - but there is still some light shinning in the room off the PJ.
Ignore me you are happy with it - which is what its all about - most bat caves I have seen use black paint etc - there is still 1 better than that which I will be trialling this weekend :)
PS you was right about a different setuo for HC to HiFi - you cant really have HiFi and a PJ as th HiFi is in the bloody way :)
Son_of_SJ
325
bigboss said:
gel said:
bigboss said:
Thanks El Hefe! :)
Hello chaps, especially to bigboss,
I had meant to write earlier, but I've had appointments most evenings this week, plus I'm going away very early tomorrow (Saturday) morning, back late on Sunday. So it might be until Monday that I can report fully. But in summary - Dolby Atmos not so sure, projector/screen excellent.
ClassAct
31
This is a pukka set up. :) How are you finding the move from Yamaha to Marantz in terms of sound quality and ease of use?
duaplex
214
I absolutly love it!
Well done BB this is super stuff and glad you went for the Draper screen there. I'm going to show this setup to a friend as he is doing something similar!
Thanks ClassAct! Marantz is a lot more musical and easier to set up than my previous Yamaha. Even with movies, it is definitely better.
Thanks duaplex! It did involve a lot of headache, but happy with the final results. :)
richardw42
299
Hi BB
How are you getting on with the Roomie Remote ?
I'm having my installation on 30 June, the installer recommended the Pro Control remote, but it £300 and still needs programming.
So I have downloaded the basic RR app for 3 devices.
I intend to control a Apple TV, Sony BDPS6200 and Marantz SR5009 from the app. The screen will be controlled via the DC trigger on the AVR.
I've had a play on my TV system with limited success, my Samsung tv works fine, a sony BDPS570 will not work. I've noticed on the Compatibility list this model is in black (rather than blue) I haven't tried it with my current ATV yet.
Ive looked at a vid on YT and setting up activities seems quite straightforward.
Roomie works well, apart from few quirks. It cannot switch the projector on with one button. I need to toggle the projector on button.
The biggest issue is touchscreen interface. I prefer button remotes. For this very reason, we tend to use the Harmony mostly, and roomie only occasionally. In the hindsight, I would've preferred URC. Pro remote looks good. How are the reviews?
richardw42
299
Not too bad, but it looks pretty complicated.
It requires some programming and I don't think the software is AVAILIBLE to the general public. I'm worried if I change any equipment it'll be a right faff changing the remote.
I got it programmed by the dealer. You can back up the settings to dropbox. Adding an equipment shouldn't be much of an issue. The forum on roomie is very good, and people are generally helpful.
richardw42
299
Sorry, I meant the PronControl, I'm optimistic about the Roomie but won't really be able to try it properly till the install next week.
richardw42
299
I found the Roomie Remote didn't really meet my expectations. Power toggles didn't work & it wouldn't allow Trigger use (although I think you can buy an add on).
I decided to set up my Logitech Harmony One & it works perfectly.
My Marantz SR5009 has DC trigger and is connected to the screen which means it lowers and raises when amp is powered on/off. Thing is if you just tap the off button on the Marantz remote or Logitech etc the screen goes up only a couple of cms. You need to hold down the power off button to send the instruction, I've worked out that a quick double press on the Logitech does it too.
PJPro
274
Hi Big Boss.
I'm rebuilding my living room (I've been rebuiling the entire house for some years now!) and am struggling to decide on the speakers to use. Originally, I intended to go for Monitor Audio Silver 6 front and center speakers with side and rear Monitor Audio in-ceiling speakers with a Subwoffer.....basically a 7.1.
However, I am now considering ditching the traditional speakers all together and going for either on-wall fronts (Soundframe) or CP-WT380 IDC in a DIY on-wall enclosure (I've checked with MA and they are suitable for this) or go the whole hog and install the CP-WT380 IDC in-wall. This latter option will cause me some pain but is dobable. I'm keen on the clean look of the in-walls but it does mean things might become tricky if we should sell the house.
However, my main concern is whether the speakers will perform. Would you be able to provide a few lines stating your feelings towards your CT280-IDC speakers? Why didn't you go for the CT380-IDC, which I think you origianlly planned to use? How much of a sound compromise is there is going for in-wall speakers when compared to traditional speakers?
Many thanks for any thougths, advice or recommendations you can offer.
Regards, PJPro.
Status
