My AV system (hopefully)
True Blue
185
http://s967.photobucket.com/albums/ae152/Humner/?action=view&current=2010015.jpg
http://s967.photobucket.com/albums/ae152/Humner/?action=view&current=2010013.jpg
http://s967.photobucket.com/albums/ae152/Humner/?action=view&current=2010009.jpg
http://s967.photobucket.com/albums/ae152/Humner/?action=view&current=2010016.jpg
http://s967.photobucket.com/albums/ae152/Humner/?action=view&current=2010017.jpg
http://s967.photobucket.com/albums/ae152/Humner/?action=view&current=2010018.jpg
http://s967.photobucket.com/albums/ae152/Humner/?action=view&current=2010019.jpg
Sorry had to do it that way as when I click on the tree thingy I just get a blank box!! (JD Help!! - am using google chrome)
Messiah
That should be all of them...
John Duncan
Ah but yeah but no but. Just so's you know what do do next time - under each photo on photobucket, there's a link beginning [ IMG ] (without the spaces).
Copy that into a post like this:
[ IMG ]http://i967.photobucket.com/albums/ae152/Humner/2010015.jpg[ /IMG ]
without the spaces.
Except that's a big photo so resize them to 400 wide...
Messiah
True Blue:Cheers Messiah, how did you do that BTW :)
Fortunately for me the Tree Icon works. So I just copy the image location, select 'Top' from the next box and then enter the relevant dimensions in the next.
True Blue
185
As above you can see not the ideal room layout, but it fits in as a family room. Big change by placing the surround speakers high, the subwoofer is sat behind the TV just incase anyone is interested.
Thanks for looking :)
Craig M.
127
they're getting bigger
nice setup, do the rears work well up there? if i went for surround sound that's how mine would have to go.
have you got a dedicated hifi room? get some pics of that up
incidentally, you might find flickr easier to adjust the size - you just change a letter in the url.
True Blue
185
I know (will be getting in trouble!!) wish I knew why the are that size they are 400*300 in photobucket.
Yes seperate hifi room, currently undergoing tactical repostioning of furniture to see where things sound the best, then I will decorate and post some of that :)
As for the surrounds still using my old audyssy settings and they sound fantastic much more depth. Cant wait for a quiet 10 minutes so I can re calibrate
Craig M.
127
True Blue:
i know exactly what you mean, i went through a period where every time the missus came home from work, the living room was completely rearranged. she loved it really...
True Blue
185
True Blue:
<img src="http://i967.photobucket.com/albums/ae152/Humner/2010011.jpg" width="400"/>
Right thats it!! exactly as you posted Mr Duncan and its not working (sob sob)
True Blue
185
Just logged in through IE and still the same:-(.
Will only have a couple more photos to post when my Hi fi room are finished
True Blue I use both Chrome and IE and no problems here: Just simply right click on the image>copy, then right click>paste the image into your reply box. Quicker and easier than using the 'tree icon' or using img src code.
Like this:
True Blue
185
The Force thankyou. Well thats it, my system. There will be another leather chair (mine!!) opposite the TV on the back wall. 11wks lead time. Till then.......
